Euro Lights... if anyone is interested..
no affiliation with the sale.. found while browsing.<ul><li><a href="http://www.audifans.com/marketplace/show.php?table=pm_audifans_Parts&id=2686">Euro Lights.</a></li></ul>
Can't H4s and H1s be installed in the non-euro fixtures? Or is the bulb opening not the same size?
glad I'm still young and my bat radar still works well... then again if I had money I might even consider those!
I have them and $450 is a good price. I would pay the full price again if I had to. If you buy them you can buy a plastic stick on protector to keep rock chips etc from breaking them. They can also be mounted with aiming motors to raise or lower them.
so fitting in higher wattage or different bulbs is a waste of time, plus if you start thinking of fitting in different bulbs you have to splice in different bulb connectors. And if you put in higher wattage 9004 bulbs you'll probably damage your wiring harness, so then ya have to relay the harness etc etc.
"And if you put in higher wattage 9004 bulbs you'll probably damage your wiring harness, so then ya have to relay the harness etc etc."
I thought "crappy 9004 bulbs" was what you wanted to get rid of?
