finally got vag com and pulled all my codes
This is what the results are.
VAG-COM Version: Release 409.1-US
Chassis Type: 44 - Audi 100/200/V8 C3
Scan: 01,02,03,08,15,17,25
Address 01: Engine
Controller: 441 907 557 DA
Component: MOTOR D01PMC 8
Coding: 0261203011
Shop #: 1267357228
4 Faults Found:
00525 - Oxygen Sensor (G39)
03-10 - No Signal - Intermittent
00540 - Knock Sensor 2 (G66)
03-00 - No Signal
00561 - Mixture Adaptation
14-00 - Adaptation Limit (Add) Exceeded
00513 - Engine Speed Sensor (G28)
03-00 - No Signal
Readiness: N/A
I am having the o2 sensor replaced on wednesday. How important is the knock sensor? I will have that done next when I get the $$$$
Address 01: Engine
Coding: 0261203011
Shop #: 1267357228
4 Faults Found:
03-00 - No Signal
03-00 - No Signal
Readiness: N/A
Fairly important. There are two knock sensors, they "listen" for irregularaities, and redard timing as deemed necessary by the ECU.
When the knock sensor is inoperative, if you have bad fuel or something else happening the ECU cannot correct it. (as it doesn't know there is something wrong).
Boston Driver
06-04-2008 09:48 AM
justwentgerman212
10-17-2004 12:19 PM
ncttrnl
03-22-2004 07:15 AM
