fluctuating RPMs on 3b 20V?
Hey all,
first thing to figure out on the new 1991 200 TQW. It has an odd fluctuating rythmic hesitation when driving constant speed- just enough to feel. Then I found that when stopped, if I step on the gas and hold it steady around 2K-3K rpm that the rpms will begin to drop several hundred rpm for a few seconds then come back up, and then drop again, and so on -in a cycle. It'a about every 5 seconds or so...
This is not apparent at idle.
Any ideas?
Any ideas?
could be
an undercharged AC system kicking in and out. Try turning the climate control to "econ" and see if it still does it. Even in cooler weather the auto climate control will run the ac (unless it is below 40 degrees or so). If the system is undercharged it will cycle on and off because it has a low pressure cut-out switch.
thats what i replaced when mine did that and it fixed it for the most part
it still does it very mildly, maybe only 2 or 3 times sinse i replaced it and it has been a while but ya that is it, i think i might have some old wires going to it causing it to surge very slighty when it does.
I noticed something similar
I've been driving my 200q20v for only a week now, and I noticed that during steady state throttle, or very slow, gradual, acceleration I can feel the car almost surging. I haven't noticed the big changes in rpm's you describe, and the frequency seems faster.
Mine seems like it's going a tiny bit faster, then less fast, then a tiny bit faster, etc.
I asked an Audi tech friend of mine and he said that's how the cars are. However, your symptoms sound different than mine.
I just passed smog and I haven't had any other strangeness, but maybe a new O2 sensor would help (my problem).
Re: I noticed something similar
interesting, yea I would describe my sensation as a hesitation more than a surge - but they are two sides of the same thing in some ways. Well, Im going with an O2 for now and see what happens
good luck!
good luck!
Yeah, probably two sides to the same thing. If I was accelerating and it didn't, I would call it a hesitation, or a stumble (altho' stumble sounds even worse). When I try to maintain the same speed, the car likes to sort of go/rest/go/rest.
wilfred2k5
9
12-29-2012 01:09 PM
sk88erguy
Audi Original "S" Cars
06-17-2008 12:39 PM
audimafiaoso
05-20-2007 09:45 PM
