Front brake ticking/rattling when hot....
My right front barke is ticking/rattling when the brakes start to warm up. The only way I can get it to quiet down is to firmly apply the brakes. Then it is quiet for a couple of minutes and starts to get noisy again. Any ideas?
I just had the rotors turned about a month ago. The pads are still good also. I checked to see if the slide pin was hanging up but it appears to be fine. Also the brakes do not appear to be overly hot so I don't think they are sticking...
Steve
Michigan
Steve
Michigan
Maybe your brake pads are moving inside the caliper a little. It happened to my dad's Ford and it was a mystery for long time before i discovered the reason - 15k miles old pads needed some insulation to be attached to them so they do not "vibrate" in the caliper. Problem was fixed.
will try to rememdy the situation when I have the time...
I think it get worse with th heat due to the pads and rotors expanding, which causes the "rubbing" to get worse...
Thanks.
Steve
Michigan
Thanks.
Steve
Michigan
While I was changing the Starter I noticed pad wear, Inner pads very low Outer pads thick, Calipers?
Mushasho!
Audi Original "S" Cars
02-23-2007 09:50 AM
spdracer53
01-30-2003 04:50 AM
audifirst
06-06-2001 06:47 PM
