Front diff lock
Where on the trans is the lever physically located that engages the diff lock on an 87 5000tq?
I assume it is vacuum operated?
The indicator light comes and goes on and off, I am looking to find out if it is the diff itself physically locking or just a switch down there that is flopping about?
vacuum actuator is on pass side, above the right output shaft. From there a rod pulls on the actuator, way back, near the rear output shaft (right side..).
Then the switch for the light is actuated by the lock or something, inside the diff... (opposite the lock rod, still on the right side)
So unless the switch somehow fluke works when you lock it, but not when you unlock it, it's working.
you may have a beggar of a time unlocking the diffs - once locked, the diff will only unlock when unloaded - possibly if you back up and drive forward a bit the driveline may let go of the diff enough.
Cheers!
Cheers!
However the solenoid itself is completely missing. Nothing is there at all.
Where is the electrical switch that detects if it is locked? I can lock/unlock manually at the transaxle all day and nothing changes on the light/dash.
The_Hamster
05-20-2008 08:33 AM
MiB@100-2.3NF-91
11-07-2005 06:52 PM
villainS4
06-16-2005 10:14 PM
