Fuel rail O-rings/copper washers
I just got the 3B engine running in my car and I have a fuel leak. Does anyone know where to get those copper washers on the fuel rail of the 3B engine? Or a part # ?
I cant find the right size anywhere.
Thanks!
Thanks!
Usually Rod at TPC can get them for you, or the dealer should have some, worldpac places should have them as well. I'll check when I get home for the part number for them if you don't have it. I've got a local foreign auto place that has all sorts of sizes of them. But, when I've ordered them from Rod, I usually get a dozen or more of each just to have them for later if I need them.
You could anneal them too, discussed on the audifans list last week. Heat them up to glowing with a propane/mapp torch, then drop them in oil to cool them. They should be good for another go at that point. No BTDT, just another suggestion. I'd replace them, though, they're cheap when you can find them.
in Santa Clara CA here for 60 cents a piece.
So I will certainly get a few extra.
Time to get this beast on the road!
Thanks again.
Thanks again.
<center><img src="http://pictureposter.audiworld.com/54799/3bfuelrail.jpg"></center><p>If you are talking about #40 on the picture, than part number is "N 013 812 8", name "seal" and remark/size is "A12x15, 5x1, 5".
mau
05-09-2002 02:54 PM
