Gamma CC instead of Gamma/Bose with Bose Speakers. Is it possible?
Hi all.
I have searched but haven't got to the issue.
As I was going thru the rear speakers refurbishing ( amps), I unhooked the harnesses and I realice that there is something a bit messy.
I found the 10-pin connector down there, plug it, and I have rear speakers working and IC display, althought rear speakers have a bad amp ( under repair)
The middle connector ( 8 pin ) has 4 cables ( white and grey/white ) were you can read "Left rear, Right rear) These are cut. However, I do have rear speakers working, and the fader function works. The other cables from that same connector are cut and wired with other cables that ( I am guesing ) go to the front top speakers.
Now, where do the front door speakers cables go on the connectors?
And then I thought about he Head Unit
My radio is an standard Gamma CC unit. On the front end, you can only read "Gamma" and not "Gamma/Bose".
The speakers ( front and back ) are defintely the Bose system ones ( including the front door, big ones).
But my question is if the Gamma ( non Bose marked ) works as the marked Bose Gamma one.
This is the one I have: Exactly the same with the gala button
http://www.google.es/imgres?imgurl=h...ed=0CB4Q9QEwAg
And this is the "other" Gamma ( the one with "Bose" written on it:
http://www.ibiblio.org/tkan/audi/radios/gamma.jpg
Do I have the good radio?
Thanks
**Edited to update info
Thanks
k04rs4
02-19-2007 12:43 PM
justinr488
02-14-2004 12:38 PM
