Has anyone swapped an URS4 cluster into a 200 20v?
My existing cluster is starting to do all the quirky things when the connections need to be resoldered and I have a nice cluster from a 93 s4.
Thanks!
Thanks!
swap the gauge faces or the individual gauges and not the entire cluster.
several folks have the white face gauges in 20020v, but I don't recall what they've done. it would be a nice writeup when you figure it out.
It will fit and work, however the ur cluster had a clock instead of a volt gauge(annoying) and the 93-up had no mfa(annoying)..You can simply swap the gauge faces over into the 200 cluster, but you will need to source a white voltmeter face...
S90RTRRO
13
08-30-2006 06:13 AM
ATH
01-29-2005 03:49 PM
PitViper
07-20-2003 03:34 AM
ZephyrS4
04-10-2003 10:20 AM
