Having problem with loading ETKA 7...
When loading ETKA 7 I get the following error message.
Datei C:\et_inst\hdc\etka_au.ini konnte nicht kopiert werden
Also I get this error message as well
The system has no fatclient of ETMaster 2000 server
The installation will be aborted
Can anyone tell me how to load program step by step.
I'm guessing that the ini. files must be loaded first, but how i just don't know.
Any help very much appreciated!
TIA
TIA
You cannot install from the hard drive, you have to burn it to a DVD., Also if there is an existing folder named "ETKA" in the C Drive you have to rename it,(because it will not install if that folder is there).
Search down the posts a couple of weeks, I talk about it more there.
HTH,...
Scott '90 V8Q x2
HTH,...
Scott '90 V8Q x2
Lane Shark
Burn to DVD or you can use an emulator like Daemon tools.
Post back if there's still a problem. After that it should load like a normal program. In my earlier post I'd assumed you were loading from either a dvd or emulator.<ul><li><a href="http://www.daemon-tools.cc">http://www.daemon-tools.cc</a</li></ul>
you only need to run setup. From what have tried, it also can only be installed to the "c" drive. I tried to install it to another, drive and the install fails. so I'm only going on my own experiences.
Also, the progress indicator does not move, but it installs fine.
HTH..
Scott '90 V8Q x2
HTH..
Scott '90 V8Q x2
rarewolf
03-27-2014 02:29 PM
