Here are my custom oil lines for the turbo and oil cooler
<center><img src="http://pictureposter.audiworld.com/49170/oil_lines.jpg"></center><p>I replaced 3 out of 4 of the old lines with these. I am really happy with how they turned out
And to think I only spent $160, which is about the price of one line from audi.
<center><img src="http://pictureposter.audiworld.com/49170/oil_lines2.jpg"></center><p>
If anything ever happens to the lines, all you have to do is unscrew them
Never having to worry about getting those rusty fittings off ever agian! success.
Adam, could you go into a little more detail on exactly how you did those lines? My lines are still the original and I want to change them before they turn into an "issue". Your solution is great, certainly better than going with those over priced factory ones. Thanks.
Randolph
87 5KCSTQ
93 928GTS
Randolph
87 5KCSTQ
93 928GTS
My buddy and I at the machine shop did all the measuring and ordered the fittings. The lines were made at a special shop that does that sort of thing. The lines are the same as the factory ones (thermo-plastic) So I am confident with thier reliability. If anyone wants the fitting sizes and stuff, I may still have them written down. E-mail me.
Adam, make up a parts list and I'll post it on my site...
Looks good btw!
Also, the package arrived at my place, should have time to redirect tomorrow. ;-)
Looks good btw!
I'm just about to change mine when the part comes in ..... are they hard to change ? I can see a couple of allen head bolts
that have to be loosened ..which scares me ...any tricks you know that might help me.
thanks in advance
Dave
thanks in advance
Dave
I dont remember what the lengths of the hoses were? So you'll have to do the measuring for that. You will need to cut off those factory plate fittings and save them. A bigger hole must be cut into them and then threaded. Then you will need to attatch the pipe thread fittings to these (use sealant). Have a hose place make you the lines and crimp on the jick fittings. The smaller line is a size 8 jick. The larger line is a size 12. Both turbo lines will need a 90 degree bend in the fitting. Bring them the old lines and they should be able to figure out the axact bends for the fittings. The line is thermo-plastic, it has a another name but I forget it? it's thermo-plastic inside with steel braided outside. As for the oil cooler, we just threaded it and put the pipe thread fitting in place. I will get the pipe thread fitting sizes tommorow for everyone.
Adam.
Adam.
I heated up the bolts with a propane torch, then tapped on them with a hammer. Just to make sure the rust broke loose. I heated them up several times before they broke loose. Make sure you use a METRIC allen bit on a ratchet, dont get lazy trying to use a standard size
You'll just end up stripping the bolt head.
![Frown](https://www.audiworld.com/forums/images/smilies/frown.gif)
iKhmaiFoSho
2.0T FSI Discussion
03-31-2016 12:05 PM
BlackS4tt (Josh)
15
08-09-2005 07:27 PM
BSCA4
10-03-2003 03:26 PM
Crapple0
04-03-2003 09:04 AM
