hot day - hot motor - no start - open gas cap - started right up
is there some clever german thingie that keeps the fuel pump from running if there's too much pressure built up in the tank? or was it a fluke?
87 5ktqa - boxerchipped, strapped, sprun, fuched and euroed
If you get a whoosh when you open the fuel tank filler cap, your tank isn't ventilating through the carbon canister (#1) like it's supposed to, usually because the solenoid valve (#9) isn't working. The ECU may not allow ignition if the valve doesn't relieve pressure??? I don't know but it's a guess.
<img src="http://www.vagcat.com/p/B062/025050.png">
Perhaps you have a hot start problem caused by leaky injectors or bad CPS/timing sensor and there was enough time for them to cool off before you discovered the gas cap off works?
BTW, I once had a similar situation where the car wouldn't start and I undid the gas cap for some reason and got it to start only to find my problem was a leaking rear fuel line...got any leaks back there?
Steve
Michigan
Steve
Michigan
Had this exact scenario in New York City with my 1980 VW Scirocco many moons ago. Whoosh sound was heard. Car started up as soon as I sat back into the driver's seat. Then it was Garden State, here we come!
It may have happened once or twice after that on a hot day & long trip but not a constant problem so I never did anything about it.
SilverHotz
06-14-2012 08:11 PM
RICHELIEU
01-14-2009 05:52 PM
vegasS4
06-14-2007 07:11 PM
