I need a crank position sensor for '90 200qa
My hot-start problem has recurred. I need a crank position sensor. The part is stamped RS-102B. It's in an aluminum block with RS-101B, and I can't get them out of the block, so the block with both would be most convenient. I think they're the same sensor with different color plugs. RS-102 or RS-101 from a 5000 should work too, just won't clip into the firewall the same. They are on the left-rear of the engine block, visible below the afterrun pump, held on by two allen bolts, in case anyone knows of a donor car.
This isn't a common part to fail, and is proving hard to find. Any ideas?
Scott Miller
Holland, MI
'90 200qa
Scott Miller
Holland, MI
'90 200qa
All Z Time
12-29-2005 07:14 AM
wdbdel
10-24-2001 06:39 PM
Unfair
Misc. Models Discussion
04-14-2001 07:30 PM
