interior lights.....
Kind of a dumb little question, but mabey this has happened to someone. The interior lights come on when i open the back two doors, but not when i open the two front doors. Mabey someone has gone threw this and can just give me a quick answer, but if not its not big deal and i should be able to figure it out...I just thought id try before i started diagnosing.
Re: interior lights.....
Did you check the front light switches to make certain they're set to turn the lights on when the doors open? They have three positions, one is on, one is on when the door opens and one is off.
I have a similar problem. all my interior lights work when i switch them on but dont turn on when I open the door, even with them switched to turn on when the door opens.
how bout the door switches??
There located on the "B" pillar as soon as you open the door. They have..or should have a little rubber boot covering a small plastic shaft.
Notorious for flaking out.
I've got a ton of them..never know when you'll need one :-)
StarryTripper
16
01-24-2007 08:09 AM
XcellR8edAudi
12-08-2004 01:36 PM
