Let's compare Audi "to do" lists... <edit...#2. >
#12
Aside from these, I just got offered another 91 200q sedan and wagon an hour ago, do i need more patients? perhaps patience... ugh
91 200q20v Avant #1-
new tires, rusty brake lines, leaking fuel tank, hot start, flaky cluster, vc gasket, breather hose r&r, rust eradication, seat heaters inop
91 200q20v Avant #2-
cat back exhaust, full front/back suspension rubber bits r&r, cv boots r&r all around, rear bearing, window switches, steering rack r&r, struts/shocks, dash lights inop, e brake cables frozen, headliner down, sunroof inop,
91 V8 5spd- clutch r&r, steering rack r&r, struts/shocks, radio inop, tires
93 V8 - head gasket leak, timing belt service, steering rack r&r, battery drain
91 90q20v - loud throwout bearing, mfts, struts/shocks, blown cat
90 100q - brakes all around, full tune up needed, exhaust system rotted out, e brake cables frozen, timing belt service, v/c gasket
97 A6q Avant- heater core r&r
#13
Chop down Shade Tree, light stump on fire with old Pentosin and build a freakin' garage.
I'm gettin' too old and crotchety to wrench outside anymore![Wink](https://www.audiworld.com/forums/images/smilies/wink.gif)
Then things like a beer fridge and a parts washer could go on Santa's list for 06!
#15
My list:
(after reading y'alls I don't feel bad):
'90 V8
1. Diagnose and fix rumble in drive train. Hope it's not the propeller shaft.
2. Buy a factory manual/CD.
3. Fix the passenger door latch.
4. Rear Defroster.
5. Change Tranny fluid and filter.
6. Bleed the brakes; this is a heavy car but it should stop better than it does; rotors and pads were replaced by P.O.
7. Replace Muffler(s).
8. Diagnose cold running and fix; thermostat/sensor.
9. Diagnose wimpy defrost; probably infamous flap/door/spring/servo assembly in HVAC system.
10. Drive the be-jeebers out of it. This thing is fun!
'90 V8
4. Rear Defroster.
#16
-Fix exhaust manifold (studs, gaskets and the such)
-Front suspension needs some fixing
-Rear camber links (?)
-Alignment
-HVAC...definitely
-Fix boost problems
-Chip and Wastegate spring after fixing said boost problems
-Fix e-brake (not so important)
-Possible headgasket change
-Alignment
-HVAC...definitely
-Fix boost problems
#17
Things I have to do:
Rear ebrake + calipers
Redo doorjamb wiring
Fix cruise control
Now things I want to do...thats a different story.
Steve
Michigan
Fix cruise control
Steve
Michigan
BigBobELK
07-23-2007 02:22 PM
|skolnick
10
11-14-2006 09:48 AM
Biscuit141
Audi 100 / A6 (C4 Platform)
03-30-2006 03:03 PM
robt_ca
02-20-2006 07:34 AM
