Lookin for a Fuel dist... I think
Hey, I still have that problem with my car not running, haven't been able to tackle it recently, but the bird is down for now, so I need to get this thing done. Still got the Start it, no idle thing. My ICV is most likely bad, I have checked most any Vacuum leak I could find, (sjm is my friend) and am good on all of that now, not really sure what to do next, but I suppose I have to check my fuel pressure to see how it drops. I dunno what to do really, but I'm thinking about just redoing the whole fuel side of the motor since i got nothin better to do. Hmph.
Pull the injectors, and stick them in a clear jar or plastic container. Open the air box, and pull out the air filter. Turn the ignition on without cranking the motor. Ignition "on" car not running. Push up on the air metering plate. Fuel should start to flow from all the injectors at similar rates and spray patterns. If not, then you've got bad injectors and/or fuel distributor. Recommend changing your fuel filter prior to installing new/rebuilt fuel distributor and/or injectors.
HTH,
Jim
HTH,
Jim
