Looking to order this drive shaft rebuild kit, any concerns or comments.
<img src="http://www.blauparts.com/Transmission/B443%20500%20003_B.JPG"><ul><li><a href="http://www.blauparts.com/parts%20dept/driveline/Audi_Quattro_Drive_Shaft/Audi_Quattro_Drive_Shaft_Propeller_Shaft_Kits.shtm l">http://www.blauparts.com/parts%20dept/driveline/Audi_Quattro_Drive_Shaft/Audi_Quattro_Drive_Shaft_Propeller
You will need an alignment tool to keep the driveshaft straight while you measure and shim the center support bearing. If you do this incorrectly you will know it because the vibration is impressive.
I've also got BMW's and this place has been highly recommended for BMW driveshafts, they also do audi.
Says $425-455 shipped, balnced all new parts ready to go. $60 core, prepaid return shipping for the core.<ul><li><a href="http://thrashdriveshaft.com/import2.htm#AUDI">http://thrashdriveshaft.com/import2.htm#AUDI</a</li></ul>
davenew
09-05-2006 01:37 PM
ElemTTRo
04-15-2005 09:27 AM
im replacing my wheel bearings with the ecs kit, where can i rent a press at? is there any other ...
Azncrombieguy
10-20-2004 04:56 PM
dvandentop
12-16-2002 10:38 AM
