Lucas Power Steering Stop Leak
Old 02-27-2013, 06:12 PM
  #31
toml99's Avatar
Originally Posted by audi_marv
Buy a pump and install it yourself. Search the net. $250 at Advance Auto, with a lifetime warranty.
Install is not that difficult. Drain Reservoir. Loosen/remove belt and hoses. Remove bracket bolt. Reassemble with new pump. Refill with proper fluid. Start car with reservoir cap off, and turn wheel back and forth to purge air from system. Top up fluid to Full mark.
With what i can get a rebuild kit for, I can rebuild 31.25 pumps for $250....You could get a new plug wire set and the pump kit, and still be a bit short of $250. I for one think rebuilding the pump can be one of the most rewarding/satisfying $8 you can spend on your car....Tom
Old 03-01-2013, 10:12 AM
  #32
dkarten's Avatar
This Product worked 100% for me with 1 application
I had already replaced rack in 2006, car now has 350K, I didn't want to replace it again & tried a product I found on Ebay: http://www.ebay.com/itm/180729562655...84.m1438.l2649
THIS STUFF WORKS, it not only stopped leaking but the car is quieter over bumps & the steering feels like new. this replacement rack always thumped & sounded ratty, I thought it was the age/mileage of the car but now see it's the rack, been over 1 year & no problems whatsoever
dkarten is online now Report Post
Old 05-18-2013, 07:27 AM
  #33
5kcstq's Avatar
That link doesn't put up any active auction. What is the name or search term that can be used to find it?
Old 05-18-2013, 10:16 AM
  #34
yodasfro's Avatar
The stuff is called SealLube however I would strongly caution against using it. After reading dkarten's post I thought it's worth a shot! Boy was I wrong it turned the slowly weeping re-maned rack into a full on hemorrhage with in a day dumping all the fluid just as my mother pulled into the driveway luckily. One thing I can recommend is using redline power steering fluid in place of the factory hydraulic fluid it's much cheaper and works just as good if not better.
Old 05-23-2013, 01:03 PM
  #35
dkarten's Avatar
sorry to hear you had such a bad reaction to Seallube, I'm still driving that car with absolutely no leaks after 1 application of that stuff
Old 06-11-2017, 12:45 AM
  #36
Unclescrooge's Avatar
Default JSD auto parts
Originally Posted by luojiashanxia
Hi,
My power steering pump had some leakage right now. I don't want to spend $700 on it to replace it. I am wondering whether the Lucas stop leak work or not. Thank you very much in advance for your help.
i just bought a brand new power steering pump w/ the pulley for $58
Old 06-11-2017, 12:50 AM
  #37
Default Here's the link
But I do want to try the Lucas power steering synthetic fluid additive but want to hear some reviews first because I use the fuel injector cleaner once every month
pcoliver
Q7 MK 1 Discussion
10-08-2012 01:23 AM
NickAudiA4
12
02-08-2007 07:08 AM
Maverick2026
11-12-2005 08:47 PM
rborden
07-20-2003 05:57 PM
O000a4
05-28-2001 04:43 PM
Quick Reply: Lucas Power Steering Stop Leak
