minor water pump leak
on my son's 1990 Audi 100. Has anyone had any luck with bars leak tablets or other sealers. And if so where do you put the sealer in (expansion tank or upper radiator hose?)
Or would you suggest replacing the pump and i supposed the timing belt while i'm at it. Thanks
If the water pump is beginning to leak, it's telling you it's on its last legs.
Most water pumps are designed to weep first as an indication that the inner seal around the bearing is going. The bearing is compromised.
It will eventually seize and may snap the timing belt.
I've never had any luck with bar's leak or prestone stop leak. I've tried these in old Detroit motors and imports.
audi49t
06-09-2010 05:43 PM
