need help on this
starting to get some low oil psi, @2000 ,100c,3 bars. at idle about 1,6 bars.no noise from the motor tho.runs strong, question is....can i just drop the pan and replace the con-rodand the main bearings?seams like a simple job. thanks
Replacing the con-rod bearing is no problem. Replacing the main bearing can be a problem depending on the type of bearing you purchase. Get the main bearing with individual thrust washer other wise you will have to remove the crank to replace the bearing.
Drop the subframe to give you access to the rear oil pan bolts. You just drop the subframe, you don't have to remove it.
Aarock_32
12-14-2010 07:25 AM
StoneMan
13
02-02-2008 07:33 PM
lolyf
04-13-2006 12:04 PM
