NF engine Intake vaccum hose. Which one?
it can be added to fresh engine oil, right after you have changed your oil, or added to a full tank of gas. For best results, do both.
It is a detergent type product, so with oil, it cleans oil passage ways, and helps stop valve clatter.
Mixed with the gas, it cleans injectors, and around the valves.
Always makes my car run better.
It is not a product that would be added through an intake vacuum hose..............Rooster
all say to pour through direct manifold vaccum line that will fill all cylinders. Possibilities are PCV valve or brake booster.
Do you know what vaccume line will fill all cylinders?>
DenimBlueB6A4
11-15-2007 07:47 PM
psuaudi
12-07-2006 07:55 AM
EastSidinA4
07-21-2005 12:16 PM
SprinTTer
11-18-2003 10:10 AM
