O2 Sensor research...
OK guys after looking around a little I see that a 4-wire universal is recommended because of the signal ground wire addition to the standard 3-wire set up. This makes a great deal of sense here in the salt belt as I assume that almost every connection is corroded somewhat by now and that the 'ground' on the exhaust is probably about the worst possible.
Through UAP/NAPA the universal Bosh 4-wire is $129, the universal 3-wire is $90, and the 3-wire 1990 Ford Taurus is $69.
Does anyone have a good part number for a cheaper 4-wire solution?
Bosch #15729 universal kit comes with waterproof connectors for splicing into the existing wiring harness. Run the extra ground to one of the ground connections on your engine. Give you a good chance to clean up that connection too. Scroll down the linked page.<ul><li><a href="http://www.autopartswarehouse.com/replacement_sm/ford~oxygen_sensor~replacement.html">Bosch 15729</a></li></ul>
Boxerfan..
I just did the 4 wire (I got it from Advanced Auto Parts Online it's 82.95) and I made the local branch match their own online price.
The Bosch Number I used is 15733.
I ran the extra ground from the drivers strut tower ground, into the oe covering.
Today I had to re-take the E-test, and passed with flying colors. Originally 147 ppm (limit of 100), this pass, 39.. sweet.. Here's the pict:
Original: <img src="http://www.scottnheather.com/audi/original.jpg"><p></p> Replacment:
<img src="http://www.scottnheather.com/audi/o2sensor.jpg">
Best,
Scott '90 V8Q
Best,
Scott '90 V8Q
98Quattro
14
05-31-2008 04:32 PM
KaMaKaZieP -ALUMIN8-
Audi 100 / A6 (C4 Platform)
08-23-2003 08:35 PM
astronmr20
12-12-2001 08:33 AM
