Occasional lifter noise on a cold engine, goes away after a minute?
Re: Occasional lifter noise on a cold engine, goes away after a minute?
same here. mines not occasional though, i can definitely hear the lifters when i start it up in the morning. it goes away as soon as it warms up. i never hear them when the engine is warm. always in the morning.
This has been discussed many many many times... it's normal
If it gets really bad or bothers you then you can replace them.
The bentley says to test the lifters you run the car above 2500rpm straight for 2-3 minutes, if it still has the sound then one or more of your lifters are bad.
Yeah, they all do that. One thing that I do notice is the oil/filter that you use has an effect on the noise too. After I switched to Shell Rotella 5W40 Full-synthetic, and used a Bosch oil filter, I could only hear lifter noises after the car's been sitting for a LONG time. So try that and see if that helps.
Good luck!
Wilson.
Good luck!
Wilson.
It does...
but the noise will come back sooner or later...
Try doing this to quiet the lifters: use Mobil 1 15-50 oil with a Mann or Mahle filter. Top up the oil to the absolute top of the full line on the dipstick. Careful not to overfill! Then run the engine a bit as Chris described in his post. If the lifters are still noisey then the only way you'll ever get them quiet is to replace them...
Do keep in mind that even newish lifters will chatter sometimes until they are pumped up with oil...
Steve
Michigan
Steve
Michigan
Yeah...
My 4k did that once even after I added more oil and let it run for a good 5 mins. I had to actally drive the car about 10 miles, then the lifters shut up.
Luongo
A4 (B8 Platform) Discussion
18
09-13-2018 10:05 AM
Luongo
01-30-2011 03:36 PM
A6 Jesse
02-20-2005 01:18 AM
98Blue
10-31-2003 07:53 AM
Craig
01-28-2000 07:29 PM
