Parking brake, or hand brake
mine hand brake is stuck too
my hand brake won't operate at all, and hasn't for some time. I guess that the cable is rusted tight inside its casing. Is that a reasonable thought? How difficult is this to replace?
Rooster
Rooster
Re: mine hand brake is stuck too
If you are Quattro it is tough because the cable is above the drive shaft. Not sure of the rest of the procedure. If you don't really miss it I would pass but be sure that it isn't causing the rear pads to drag.
Tony
Tony
frozen hand brake
My 86 5K is just plain garden variety, no turbo, no 5 speed, so just put it in park. I haven't used the hand brake in years. Luckily it is in the full "down" position, so it is is not dragging the rear pads. Still would like to learn how to fix it.
Rooster
Rooster
Re: Parking brake, or hand brake
Just found out that mine is out of comission as i recently replaced all my brakes and calipers and my hand brake cable is not relesasing my pads properly causing my pads to seize. so i took off my back wheel again and readjust my pads and i will no longer use my Hand brakes unless i change my cable.
jcanon
Q5/SQ5 MKI (8R) Discussion
02-22-2015 10:19 PM
islingtonaudi
Audi 100 / A6 (C4 Platform)
12-07-2005 12:54 PM
haudi
15
08-30-2002 05:35 AM
Ben's e//S2
07-21-2002 01:20 PM
