power window relays ?
could be a window switch. If you haven't done so, try operating the windows at the drivers door, then each individual door window. See if that does anything.
If not, pull a door panel, disconnect the wiring to the winder, use a multimeter to see if you are getting power to the winder. If so, then it's a bad winder.
Still pretty certain there are no window winder relays, only fuses.
Regards,
Rooster
Regards,
Rooster
mcorrow
02-01-2006 07:23 AM
