Radio volume control knob cutting out
Radio volume control **** cutting out
The volume control on my radio is acting up. It cuts out when trying to lower volume and acts if I turned the radio off. Wiggle or tap the **** and it turns back on. If I adjust volume with a little side load on the ****, everything seems fine. Does this sound like dust in the switch(alot of little league games recently) or something else? Would some kind of tuner cleaner do the trick and if so would I need to pull a fuse before I clean(radio turns on with or without ignition on)?? Any ideas??
Thanks, Tom
Thanks, Tom
Re: Radio volume control **** cutting out
Mine had loud static when it was turned. Had no luck ad disassembling radio and the switch was probably not servicable. Figured I would replace the part but tried to spray DOxit (Caig Labs) in the side of the ****. Static stopped and has been fine for months since.
Tuner cleaned should work about the same.
I would just have the radio off when spraying.
Can't hurt, Might help.
Tony
'91 100Q 5spd
Tony
'91 100Q 5spd
I have an extra radio in good working order if you can not get it to work but I would try...
...to clean the connection as was listed. Should work. $40 for the radio (1989 200 radio)
Thanks,
Jim Bush
Holland, MI
Thanks,
Jim Bush
Holland, MI
Andrewembassy
02-22-2005 12:36 PM
