Rear differential seal (pinion/driveshaft) on '88 5000SQ
Not sure if has been touched on before. The front seal for the drive shaft on the rear differential has a slow (very slow) drip. I can't find the seal and bearing on autohausaz.
I assume the bearing is bad since the seal is leaking. Can somebody point me at the correct part numbers? I am only seeing left and right seals/bearings.
016311235 bearing
017525275B seal
N 90297101 flange o-ring
genuine or http://www.worldimpex.com/<ul><li><a href="http://www.genuineaudiparts.com/">http://www.genuineaudiparts.com/</a</li></ul>
017525275B seal
seal 017-525-275b
o ring n 902 970 01
bearing 016-311-235
replaced lots of these never had to change a bearing yet they seem to last about 90-100 k miles
o ring n 902 970 01
bearing 016-311-235
StoneMan
13
02-02-2008 07:33 PM
Silver90Quattro
11
11-11-2003 08:34 PM
