Seized brakes, cheapest solution?
Good afternoon AW
I am a student and have a 200q20v which I used as a daily driver through high school a couple years ago. Since I moved away it has been parked for 2 years, and I believe the brakes are seized. This is the only issue I know of making it not roadworthy. What would the cheapest solution be to get this car back on the road? I really miss driving it, and seeing it parked on my driveway every day makes me sad it isn't being used.
A while ago I was considering the G60 mod (it still has UFO brakes on it), but never went through with that just because it was pretty expensive and that would mean having to get new wheels. I still have the stock BBS alloys; a set for both summer and winter tires, and they both have plenty of tread left so I wouldn't want to get rid of those just for the brakes.
I was considering buying a parts car that still had good brakes, but I wanted opinions first. The rest of the car is solid except for the suspension, but that doesn't make it un-drivable.
Let me know your thoughts.
The *cheapest* solutoin would be to replace the UFO's, with UFO's. Even if you got used rotors from someone here, or try Force 5 Automotive (or even new).
The G60 Conversion is going to set you back about the same $$ ($300 or so); G60's WILL fit under the sotck BBS wheels.
Then you can get into some additonal $$, by going to a BBK using the existing UFO housings, bu tthen you're into between $800 and $1000 - not to mention; yes you will need new wheels and tires..
Where's the car located?
jack it up and see what corners spin freely,fronts might be ok ,those UFO'S can keep for a little while since they are semi-shrouded,check that gutter side rear ...wire brush those pad guides and clean and lube them sliders...rears are a cheap proposition for rotors....just think half full....Ding
Car is located in Ottawa, Canada.
So you think for the G60 conversion it would set me back only $300? I was thinking it would be much more expensive than that, which is why I have put it off for a couple of years. Where would I go to start learning about that (besides searching here), and am I looking for used parts off of another car?
Just to get the car back on the road I probably wouldn't invest in the BBK setup, as I would only end up driving it for a couple of months of summer before I move away again.
Edit: After looking back at previous posts, some by you V8, UFO's are priced somewhere $250/ea new which is pretty steep. Perhaps I could find a parts car with a decent set on it though, which would hopefully be less expensive. I suppose I will keep my eye on the classifieds for UFO's in decent shape.
These of course are the BBS wheels (off google img).
![](http://carphotos.cardomain.com/ride_images/1/1641/3321/4101660002_large.jpg)
Location: Richmond VT...spend a lot of time in Castiine Maine though.
There are several V8's being parted currently, that you can use the entire front assembly from. They would just bolt in place, you'd need an alignment and to bleed the brakes and you're done.
join/post to the V8 list, or on AF "wanted" and I'm sure that someone will get back to you within a couple of days (if not a couple of hours).
If you were thinking of doing it "sooner" one might be able to catch the Carlisle Mule - that is Carlisle as a gathering point a person woudl give it to another that was going back to or towards Buffalo or Ft. Erie area and you can pick them up to save on the cost of shipping.. (Just a thought).
just a though....
http://www.autohausaz.com/search/pro...rake%20Caliper
They are about $100 CHEAPER at RockAuto. <--- Just saying.
Anyways, nice to see you still browsing audiworld. I kind of missed the whole audiworld/quattroworld debate, but I suppose most people still check AW every once in a while =D [/offtopic]
-Mike
