short shifter for t44?? any availible?
The classic move is too cut the shaft and re-thread. However, you can also purchase a short shift kit from blauparts.com. It's around $40. and is simply one half of the ball portion of the shifter that spaces the upper shift rod an inch or so higher. The resulting leverage makes for a shorter throw. Combine the two and it get's pretty sporty. Hope this helps:^) JB
$39 from blau. I've been thinking bout trying to make my own some how. When you get their kit, it's a little frustrating the price for what you get. After i got it i was tempted to make my own and return theirs.
The idea is to raise the leverage point for the shifter. so the ball at the bottom needs to come up.
<center><img src="http://pictureposter.audiworld.com/50623/hanksheaderstuf_001.jpg"></center><p>As you can see from the picture, i just made my own pivot out of Delrin, and then welded a piece onto the top of the rod. THe shifter can actually be made quite a bit shorter by simply putting a spacer of like 3/4 of an inch at the bottom of the rod, next to the actual pivoting ball. just slot it so the reverse still will decompress, but it moves the stock plastic piece up 3/4 of an inch and makes the pivot 3/4 inch higher for a shorter throw You can not make the spacer thicker and retain the stock "bearing" b/c the rod linkage will hit the tunnel if more than 3/4 of an inch is used at the stem. by making my own piece i moved the pivot up about 2 inches thus making the throw tiny. I wish i would have NOT cut my rod down though, it just kindof sucks now b/c it feels like my hand is just jammed in a little hole. I think i may weld something back on.
Anyways, HTH or anyones short shifter endevors..
Hank
Hank
rocketaudi
02-27-2003 02:28 PM
