symptoms of torn w.g. diaphragm?
Re: symptoms of torn w.g. diaphragm?
If your not sure take the hose of the wastegate cap attach a vaccum gauge. Draw vaccum to it and it should pump up and hold, if it doesn't it's ripped. If it does start looking else where.
Later TOX
Later TOX
Overboosting...
Do you have a boost gauge? How much boost are you getting?
Usually you'll overboost when the diaphragm tears. Leads to a quick lean condition obviously. Having a Tap chip probably not the best idea when this happens...
Do the vacum test as Toxcheap suggested. You should be able to hear the WG valve drop when you let of vacum...
I'd check ignition components if the WG control system checks out...
Good luck
Steve
Michigan
Good luck
Steve
Michigan
redsac
06-29-2001 04:48 AM
