Trunk Light Issue
I know, it is a minor thing, until you are out in the trunk at night, then it becomes an issue to be dealt with.
Scenario: Open trunk, no light. I go out today to look at things thinking how hard can it be. I take the light out of its spot and inadvertanly ground it to metal and it turns on. Light apparently works. Whatever turns it on when you open the trunk must not be working.
Refer to Bentley. Find a reference to something called Lamp Control Unit, Rear. I found that in the trunk, even traced the wires back to it. But how does that thing know when the trunk is open? I was thinking there must be a switch somewhere but who knows.
Also, why is it everytime I look in the Bentley manuals, I come away feeling like I am retarded? These books are starting to **** me off. So full of info, yet so damn unhelpful at times
TIA
Drew
TIA
Drew
When it detects a bulb out it signals the "system monitor" module in the instrument console, which will then display a "bulb out" icon to the driver.
AFAIK it has nothing to do with the trunk illumination.
I was in the trunk yesterday. Someone had a go at rewiring right where you said broken wires would be. There is a glob of electrical tape and wire nuts at the right hinge. I just know I am going to have to undo that mess and rewire. Good thing the trunk is comfy.
I fixed the trunk light in my '91 100. There's a spring loaded slider switch with a plastic plunger that moves up when the trunk is closed shutting off the light and down when the trunk is open to close the circuit. Bought a replacement but didn't need it. Just made sure the slider operated freely.
Zwoobah
Audi Original "S" Cars
11-03-2008 09:25 PM
QuattroPwr
03-04-2005 07:53 PM
The trunk light never shuts off, even when the trunk is shut and the doors are locked... ???????????
DINA
08-21-2003 10:55 PM
Alf Arkin
12-18-2000 05:31 PM
