Use of ATF in Power Steering?
...5000 must use Pestonin CHF 7.1 Hydro-fuild A.k.a. "audi gold". At least the 5000's I've owned. My Urq on the other hand must run ATF as steering fuild.
You'll need Pentosin 11s...
It's the synthetic version of 7.1 that was used on the older 5000, etc...
Audi updated the hydralic system in 89+ and you cannot use the 7.1 in the newer system.
You cannot/should not use ATF in this system.
Steve
Michigan
Steve
Michigan
They are mixable, they both carry the same PN g002000. The later cars it's not recommended to use 7.1 because 11S allows lines to be routed closer to high heat sources, the 7.1 will overheat. Think of it as Mobil 1 (11s) vs dyno oil (7.1)
If you find yourself in a pinch, Sam's Club sells Mineral Oil in bulk.
HTH
Scott Justusson
QSHIPQ Performance Tuning
HTH
Scott Justusson
wants $26 per liter of the stuff. Liter???? Who the he!! is gonna use a liter of this crap? Naturally can't get it at the corner NAPA or Autozone.....mail order?
