V8 5 Speed Swap
So I came across an Audi that has a bad auto tranny. I also came across a parts Audi 5KQ that would be my donor vehicle. I found this site and was curious if anyone had additional sites that discuss this conversion.
http://germanautoconnection.com/5-speed_conversion.htm
I am fairly mechanically inclined and know how to weld, so not all that concerned with the conversion, but just need to know more details.
The 5kq (NON-turbo) is a perfectly good transmission, shifter assembly, pedal assembly and prop shaft donor. You will also need the vacuum control stuff for the center diff locking mechanism.
You will still need 200q20v axles, and may want 200q20v transmission tunnel sheet metal (5kq will work, but not nearly as well, and you can force the stock sheet metal to work ala Adam Mowafy and Brad W.).
Anonymity
Audi Original "S" Cars
11-10-2009 11:07 PM
gragravar
Audi allroad
05-09-2007 04:09 PM
Houpty
01-16-2006 02:24 PM
- GT Style -
9
03-20-2003 01:33 AM
