V8 Fuel mileage
V8 Fuel mileage
Hi Guys,
My mileage has dropped off dramatically in the last two weeks. I've gone from 20mpg to about 16mpg. Now, it has been extremely cold here, would that have that much effect? The engine is running smooth as silk. Where should I start?
Thanks in advance.
Norm
Thanks in advance.
Norm
Re: Where you should always start..... pull the codes.
Agreed pull the codes, but also consider that you stated that it has been very 'cold' which will require the engine a longer period to reach operating temperature. The engine is probably running rich (to compensate for the cold) until it reach the correct operating temperature.
if its cold like 10 degrees or less, is it accecptable to see
dark smoke at startup once in a while, but never after that. would it be extra fuel used to start car, then burnt off?
thanks
thanks
Merkin
01-26-2005 01:44 PM
HDClown
Florida Discussion
08-05-2002 06:48 PM
