V8 Quattro Transmission
well, how does it work?
There are no gear ratios listed and from what I've read, it's programming can be reset by disconnecting the battery for awhile. I know how the 3 modes work.
What are the ratios? Are they adjustable by the transmission computer?
It's just they are already programmed into the box for specific shift points.
As for the ratios I am not sure that they are different for other 4HP24(a)'s but a standatd ZF 4HP24 trans has the following:
Automatic four-speed transmission with mode select, lock-up, electronic control, shift lever on floor,
2.48:1 first gear ratio,
1.48:1 second gear ratio,
1:1 third gear ratio,
0.73:1 fourth gear ratio,
2.09:1 reverse gear ratio,
low/high gear ranges and 3.27:1 low/high gear ratio ZF 4HP24
HTH..
Scott '90 V8Q x2
HTH..
Scott '90 V8Q x2
thanks a bunch. AW's model guide didn't list gear ratios so I didn't know if they were adjustable (is that even possible beyond a CVT?) or what.
As far as shift points go, are there just a set for Sport and a set for Economy, or does the car learn and adapt to driving styles?
As far as "I" know, it's pre-set for those specific points., you have to get into the later cars for get a learning setup. (98 newer I believe)
HTH..
Scott '90 V8Q x2
HTH..
Scott '90 V8Q x2
High Launch Low Spin
17
02-01-2007 11:41 AM
Jshwon
11-21-2002 09:57 AM
