Whats the difference between 5000 Q, 5000 QT, and 5000 Turbo for an 87' 5000 CS Quattro
Old 02-06-2006, 07:33 AM
Jon-1.8t's Avatar
Default Whats the difference between 5000 Q, 5000 QT, and 5000 Turbo for an 87' 5000 CS Quattro
Its a little confusing when ordering parts. My car has quattro and a turbo.
Old 02-06-2006, 07:36 AM
icon73's Avatar
Default Re: Whats the difference between 5000 Q, 5000 QT, and 5000 Turbo for an 87' 5000 CS Quattro
5000q, n/a engine with all wheel drive
5000qt, all wheel drive with MC1 turbo engine
5000t, turbo charge engine with fwd
Old 02-06-2006, 07:38 AM
Jon-1.8t's Avatar
I thought for that year for 87 they only made the quattro with turbo only.
jurq's Avatar
Default The 5000 CS Quattro is a quattro turbo. 5000 S Quattro is normally aspirated.
Basically: CS = Turbo. S = N/A. Therefore, when ordering, you'll give either 5000 CS Quattro or 5000QT. Depends on the part vendor, I suppose.
HTH,
Jim
Old 02-06-2006, 07:41 AM
Jon-1.8t's Avatar
cool thanks
jurq's Avatar
Default I believe you're correct. 88 started the 'S' quattro designation.
But for simplicity, parts vendors prolly list all the iterations of 5000's up until 88.
HTH,
Jim
Old 02-06-2006, 07:44 AM
Jon-1.8t's Avatar
gotcha, make sense
Old 02-06-2006, 08:09 AM
itsav8's Avatar
Default Re: I believe you're correct. 88 started the 'S' quattro designation.
The non turbo quattro 5ks were 87-88 only. First generation NF motor 2.3 lit 130HP? with injectors in the head as opposed to the later non turbo motor from the 100's. Parts for the non turbo cars are the same as the turbo quattro cars sept for some motor parts.
& the trannys were 4:11.1 not 3:89 as in the turbo cars.
Ron
Old 02-06-2006, 08:55 AM
5000CDQturbo's Avatar
you missed one the CD model , not that it matters :-)
Old 02-06-2006, 02:02 PM
New Member
rajan_bhirud's Avatar
Default CS
CS does not mean anything. It is just the trim and interior style. It does not dictate engine type, transmission type or turbo or quattro. Contact some parts supplies and they will support this.
Quick Reply: Whats the difference between 5000 Q, 5000 QT, and 5000 Turbo for an 87' 5000 CS Quattro
