What's this ticking noise under my glove box....
Old 07-04-2005, 05:39 PM
New Member
laterskater's Avatar
Default What's this ticking noise under my glove box....
I decided not to tinker with fixing the servo that people have said is causing my CC to default into full defrost and now it sounds like I have a bomb ticking in my glove box. This ticking is not dependent on whether the CC is on/off or setting of it. Is this the servo or something new to figure out?
Old 07-04-2005, 05:49 PM
Avant Sport's Avatar
Check that seat heaters are off if applicable
Old 07-04-2005, 06:00 PM
New Member
Default Re: Check that seat heaters are off if applicable
Thanks but those suckers aren't working.
Old 07-04-2005, 06:22 PM
Quattrotrac's Avatar
Default Check to see if your headlights are working correctly as well as the switch...
That sounds like a headlight relay that crapped out to me...
Old 07-04-2005, 06:59 PM
New Member
heavyiron's Avatar
Default Sounds like it could be coming from...
The controller box for the CC unit.About the only thing that can click in that area.
Old 07-04-2005, 08:45 PM
rooster 2's Avatar
Default Quattrotrac.......I like your diagnosis............
I had this happen to my climate control programmer located behind the glove box. The unit mounts on the firewall.
Something breaks loose with an arm or gear in the programmer electric motor to create the "ticking" noise. I think replacing your programmer, and your problem will be solved.
Old 07-05-2005, 04:49 AM
Default I had an old '87 5kq that did this...
The whole time it was the headlight relay clicking. I didn't think it was located back there....I know about the CC programmer too which was what I was looking for anyways since the CC on these cars usually don't work anyways..lol...but then the headlight relay was all scorned underneath...it was weird.
Old 07-05-2005, 06:29 AM
New Member
Default Any problems with lights to diagnose this?
My driver's side headlight has a problem but it is more likely due to the harness holding the assempbly. It runs low beams so I haven't felt this is a pressing issue. Knowing everything else that is going on I think it is my programmer. Damn these things are expensive....
Old 07-05-2005, 06:38 AM
Default Change out the programmer first...
The symptoms I got from the headlight issue was that high beams would stay on at all times...and everything would go off when the low beams were activated. We changed the switch, but it did nothing and turned out to be this relay.
What you're describing seems unrelated to a relay issue. Go with the A/C programmer and repost if it doesn't fix the problem.
Old 07-05-2005, 11:40 AM
rooster 2's Avatar
Default Hey Laterskater, suggest you contact Tom Serranno........
he posts here quite a bit. He once emailed me that he had repaired a "ticking" programmer some time ago. Ask him how he fixed it. If you can repair it, you will save some bucks.
Quick Reply: What's this ticking noise under my glove box....
