wheels bolts
Old 06-21-2010, 12:27 PM
  #11
V8QinNJ's Avatar
Default :-) You're Welcome.
Originally Posted by Chris@ECStuning
Blast beat me to it! Indeed we can get any lug size you need, more or less. The size and pitch is the same as older make VW's so you really luck out. Click here for a wide selection of wheel lugs from 27 to 55mm!! We came onto the scene so many years ago for wheel, tire and brake conversions and packages for older Audi's and VW's. We still try to carry most of our original catalog too!
Old 06-21-2010, 02:32 PM
  #12
gedis080's Avatar
There is no problem to remove bolt, or i don't understand what You are saying... The thing is that maximum bolt head which fits is ~19mm outside diameter.
Old 06-21-2010, 02:34 PM
  #13
gedis080's Avatar
Originally Posted by itsav8
I went with wheel studs Gedis.
You can probably get them were your at as well.
hmmmm .. http://www.boltscience.com/pages/failure4.htm
I would prefer bolts .....
Old 06-22-2010, 06:37 AM
  #14
Audiworld Basic Sponsor
Pete@ECSTuning's Avatar
Originally Posted by gedis080
OK. I will try 17mm socket tomorrow.
Any luck with this? It would make your wheel bolt search very easy if so!
:: www.ECStuning.com :: Now with EXTENDED Customer Service hours!! | FIND US ON FACEBOOK!!
Phone: 1.800.924.5172 - Sales: 8:30am to MIDNIGHT EST | Customer Service 8:30am - 8pm EST
Questions? PM us for a quick response! | Email: Pete@ecstuning.com
Old 06-22-2010, 12:26 PM
  #15
gedis080's Avatar
No, I didn't check; was busy and forgot. But just to verify (sorry for my English) what is a non-impact socket ? Is this one :
Socket outer diameter for bolt is ~12 mm
And my wheel inset is about 20mm diameter
Old 06-22-2010, 12:29 PM
  #16
If you can fit a standard 17mm socket in the hole of your wheel you wil be able to switch to standard stlye lugs as posted above and save a ton of money. Sockets designed for air powered impact guns are a bit thicker than a standard 17mm socket designed for a standard ratchet. So, if you have a 17mm socket and it fits in that hole, you can use the bolts posted above.
Old 06-22-2010, 12:58 PM
  #17
gedis080's Avatar
Standard style lugs (with 17mm heads)as posted above doesn't fits into hole of the wheel because of "skirt". I have tried that.
Old 06-22-2010, 01:05 PM
  #18
Oh oh, alright then. I'm afraid I'm no help
Old 06-22-2010, 01:12 PM
  #19
gedis080's Avatar
.... jaaaa... when I was looking for new wheels I didn't pay attention at all to bolts type. And now I see it becomes a big problem.
Old 06-23-2010, 11:26 AM
  #20
itsav8's Avatar
ball seat bolts are for most oe Audi rims while conical bolts are used for most aftermarket rims.
I think u need the later(conical seat lugs)
Quick Reply: wheels bolts
