when i turn my headlights on both turn signal arrows and high beam light stays on now what ?
the trip computer light goes dark also the turn signals work fine but the arrow blinks backwords the blue light goes out when i switch to high beam i know its in the instrument cluster but how do i fix it
Re: when i turn my headlights on both turn signal arrows and high beam light stays on now what ?
Similar symptoms on a 91 200q20v results from a broken solder line on the instrument cluster.
Link goes to a fix for that problem on that car.<ul><li><a href="http://www.lanikamal.com/audi/dashboard.html">200 IC fix</a></li></ul>
wow i just had it all apart guess i will do what you did thanks so much .deve
Re: kneale was that the ground jumper wire thats green ?
That wasn't my fix, it was someone else's who kindly provides the information. I think you'd want to take the cluster apart like he did and make sure which tracks you're linking together with the jumper. He indicates he fixed both a ground track and a power track.
new ground wire
i had the same turn signal/high beam light problems and solved it with a new ground from the negative pin of the digital clock (marked on the IC board) to good bare metal on the firewall.
Re: was your speedo jumping to?
yes...solved that problem by resoldering the connections indicated in the earlier post with pics of IC. i did not jumper those connections, but probably should have since the speedo fix lasted just over a year before i had to redo it. even though, the turn signal/high beam problem never came back.
ericcorp
Audi allroad
01-12-2016 12:24 PM
shadyraven
Audi allroad
02-11-2008 01:51 PM
