Won't start when cold
Unless I leave the ignition switch on for about 2 minutes, then it will fire up. Otherwise is will catch a little, but mainly just crank over with nothing.
The fuel accumulator's located beneath car, right side, just forward of the fuel tank. When it fails, system fuel pressure will drop between starts. A good accumulator will maintain fuel pressure between starts.
going thru a similar prob /w
5ktq check your residual fuel pressure at the fuel dist 2 cold start valve circ 3 most common prb is the resisdual f/press valve its in the tank mounted on top of the fuel pump there is 4 also a pressure valve in the fuel dist that has an O ring & has been known to cause probs as well hope this helps
UrS4boy
Audi Original "S" Cars
10
01-19-2008 10:34 AM
GrandPaJohn
06-01-2007 11:25 AM
5000turboman00
02-20-2007 10:04 AM
