12v Overheating Problem - Stuck and Need Help
I'm stuck - I'm frustrated - I need help.
I've outlined the situation below including symptoms and what has been done so far to remedy.
Car: 1993 90s, Automatic
At Idle with fans on:
- car will slowly overheat
- upper rad hose hot
- lower rad hose cool
Run car at 3000 RPM with fans on:
- car cools back to normal and holds
- lower rad hose hot
Efforts to Fix:
- new waterpump
- new thermostat
- new radiator
- new thermoswitch (although have manually turned on fans)
- system flush (2x)
- bled system a million times (broken bleed screws, using heater core hose method - lower bleed screw stuck)
Thoughts?
- blockage somewhere in the system?
- bad thermostat / thermostat backwards (possible?)
- just not bled properly?
Efforts to Fix:
- new waterpump
- new thermostat
- new radiator
- system flush (2x)
Thoughts?
I didn't mix two different kinds of coolant. In fact there is brand new Audi coolant in the car following the flush, which included an engine block drain.
Would a bad thermostat open up under pressure?
PartyBoyRacing
9
03-02-2008 01:28 PM
talltorontoguy
12v V6 Discussion
11-15-2004 11:40 PM
talltorontoguy
9
11-15-2004 10:06 AM
philip200qt
10-19-2004 10:13 PM
