1993 90cs will not start relay 208?
I was driving my car with no problems and stopped somewhere like normal, went to get in the car and it would not start. There is full power to everything but the relay 208(fuel pump relay) clicks about 2 times a second. when you turn the key no sound no movement nothing just silence no clicks from the solenoid or anything. is there a different relay dependent on thins one to work so the starter does not move?
Thanks for the help I receive!
but first check to see if the trunk wiring isn't shorting the electricals. This will happen if the wiring loom is damaged at the hinge of the trunk. Audi badly designed this area & the ancillary electricals in there. The hinge acts like a pair of scissors and in time cuts the wires in the loom. Check very carefully here. I blew several relays until I figured out what was going on. Made Shokan very rich too.
i did not notice anything out of place or damaged, I am not sure I ordered a relay so hopefully it was the problem if anyone else has any input let me know. thanks
90CSaiko
06-01-2008 08:38 AM
Yoshi900
12-06-2005 02:12 PM
Yoshi900
12-05-2005 10:49 PM
