1995 Audi 90 Power Windows and Sunroof failed
Power windows and sunroof all quit working at once. It was first an intermitent problem and then they quit. My old relay number for my 1995 Audi 90 was 4AO-959-257. This is the number on the relay that failed and I believe it was original to the car. I replaced it with a 443-959-257A and it works great. There was a large plastic clip on the side of the new one that is not on the old one. I had to snap it off since there was not a slot in the fuse panel for this clip so it would not fit. The panel for this is under the steering wheel inside the car. There are four machine screws that need to be removed. The screws are covered with platic buttons that pop out using a flathead screw driver. The bolts have a 10MM socket head with a phillips screw head inside. It is easiest to use a 10MM socket with extension to remove the bolts. I got a used relay for $75 plus shipping. Audi wanted about triple that amount. Hope this helps someone in the future.
Re: 1995 Audi 90 Power Windows and Sunroof failed
I have had the same exact problem on my '95 Quattro (intermittent then complete failure). Can you tell me where you found the used relay?
Thank you.
Thank you.
cuch80
07-22-2008 01:56 PM
fahbiz
05-31-2007 12:43 PM
Dave from Gig Harbor
10-04-2006 04:03 PM
audiauction
09-14-2006 01:34 PM
