1997 Cabrio Codes
My 1997 Cabrio is throwing the following codes:
P0170 Fuel Trim Malfunction (Bank 1)
P0173 Fuel Trim Malfunction (Bank 2)
P0174 System Too Lean (Bank 1)
I'm not really sure what these could be. I was told that they might be caused by the EGR valve needing clean, but I'm not sure if that's what it is. Any help would be great.
This is a newer car than mine (OBD I), so I'm not really familiar with these codes. Yes it may be the EGR System, but it may also be a vacuum leak which is common on the 12V engine. This write may be helpful:
http://repairpal.com/OBD-II-Code-P0171-and-P0174
Here is another write-up (from http://www.goarticles.com/cgi-bin/showa.cgi?C=2372842):
P0170 Fuel Trim Malfunction (Bank 1) P0171 System too Lean (Bank 1) P0172 System too Rich (Bank 1) P0173 Fuel Trim Malfunction (Bank 2) P0174 System too Lean (Bank 2) P0175 System too Rich (Bank 2) Check for vacuum leaks, low or high fuel pressure, dirty fuel, clogged fuel filter, clogged air filter, worn spark plugs, bad pcv valve, and any general maintenance items.
If you want to know more about EGR clening and vacuum leaks you can search for those terms here on this and the sister 12V forum.
WClark
9
05-01-2007 03:38 PM
Laughing Gnome
VAG-COM Discussion
04-05-2005 10:54 AM
marcodant
10
11-02-2004 07:16 PM
