2.7t V6 in 90CS Quattro conversion? am i being dumb?
Alright, this may sound dumb... but, has anyone done a conversion to a 2.7 motor?
Dose anyone know if the motor will fit in the engine compartment or will it bolt up to our manual trany? Or is an adapter plate/treny swap required?
It's been done, not often. The 30vtt needs some help to fit the older chassis. It will bolt to the stock trans if you run a certain clutch setup IIRC. Stock exhaust manifolds, down-pipe, etc won't work in the B3/B4, again IIRC.
Its been done, but exhaust manifolds and turbo plumping have to be reworked in order to clear the b3/b4 firewall. I don't know about the transmission stuff.
<img src="http://i101.photobucket.com/albums/m49/starch87/Cabriolet/audi20engine-1.jpg" border="0" alt="Photobucket"></a>
