20v head on a Eurovan 2.5L block
#11
I've been looking around for info on upgrades for my motor, but it appears not many folks want a boosted or otherwise eurovan. Since you appear to be pretty knowledgeable on the subject of performance VW/Audi, might you have a suggested build? My mechanic indicated that the motor was a good candidate for turbo, and mentioned the possibility of a audi donor?
any info would be greatly apreciated!
See if Chris @ Force5 will send you a picture of the driver side of the EV motor he has, would give me an idea about what sensors needed bosses drilled/tapped (i'm betting few/none).
There are a couple other things you should think about. One being, what are the wrist pin diameters of both motors. May be different. Second is, what is the distance from the wrist pin to the piston crown on both, would be less than ideal if the 7A pistons were sticking out of the EV block. The EV also has the 95.5mm stroke crank with 81mm bore cylinders, so you'll need to get the block bored for the 82.5's and honed when you have it drilled for the oil squirters. Crank will need to be balanced with the 7A pistons as well (will also help with the engine retaining the ability to rev to 7200rpm).
Something else to think about is that the Hitachi computer does not know how to deal with the extra displacement. The MAF is pretty small, injectors aren't that great flow wise, computer is not adaptive enough. One way around it is to run a custom fuel rail with larger injectors and an Apex'i S-AFC or something like that, to allow more fuel into the engine. I also have a feeling that the factory cams won't allow quite enough air in to really make a big difference in power from the 2.31L to the 2.55L motors. A set of Schrick cams would definately help out, as would the factory tube header.
#12
No Bozos!
Now this is getting interesting.
It will cost you much more than it's worth the try and tweak the 7A. If you want to spend a few (many) thousands you can get it up to maybe 300hp and make it undriveable in the process. Go 20VT.
B2119
Inline-5 Discussion
06-11-2005 04:46 AM
quattrostud908
10
11-07-2004 09:52 AM
theaudiguy
01-03-2004 12:02 PM
