90, 1988 driver side flange removal
Any BTDT to remove the CV flange of the tranny ? driver side ?
I tried but )((*&?%#%@#$%!! i cant.
The CV flange looks like a big bolt draws on center of the flange ....
it quite urgent . no car for work.
I already post it in canadian furum and Audifans.com
Plzzz explain in good english or in FRENCH. plzzz
Denis Julien
sparkplugvw@hotmail.com
Denis Julien
what I did to get mine out was, I went to the hardware store and got 2 long bolts with the same thread pattern as the bolts that hold the cv axle to the flange. From there you take the bolts that you bought and screw them into the flange until they hit the tranny. Then you will want to screw the bolts in a few turns on each side, this will make the flange come out as evenly as possible. If you screw on one side too much it might not come out as nicely. All you do is keep on doing this and the flange will eventually come off. I hope this all makes sense to you, if you have any questions let me know and I will try to better explain the process.
Nick
Nick
Oooooo thanks. you are the first i got clear reply with no something to try or use special tool.
Well, it s the only thing i did not tried.
i have some spare bolt and i ll put spacer to longer.... or like you said buy longer one.
Thanks,, i ll practice it on my old 100Q tranny,,, same configuration.
I did on lunch time, it works great.
Just to do it under the car ;-)
Must i remove the CV shaft ? or any place to work and get out the flange ?
thanks
Denis
thanks
Denis
archimense
11
03-11-2009 02:26 PM
ctlaw74
08-16-2006 06:28 AM
