93-95 90, 5-speed gearbox, "To synchro or not to synchro"? That is the question!
AudiWorld Expert
<center><img src="http://catalog.exist.ru/pic/parts/VAG11252.gif"></center><p>1993-1995 Audi 90 5 speed gearbox-
8- 3rd gear
10- 3&4 synchronizer ring
12- operating sleeve 3&4 gear
12b- synchronizer hub, 3&4 gear
14- 4th gear
16- 5th gear
21- reverse gear
Where's the synchro for 1st? Where's 1st?
<img src="http://catalog.exist.ru/pic/parts/VAG11254.gif" border="0">
HERE IT IS!
6- 1st gear
8- 1&2 synchro
9- operating sleeve, 1&2 gears
9b- synchro hub, 1&2 gears
12- 2nd gear
14- 3rd gear
16- 4th gear
19- 5th gear
21- synchro 5th gear
23a- operating sleeve 5th gear
23b- synchro hub 5th gear
26- synchro reverse gear
27- sliding wheel for reverse gear.
8- 3rd gear
14- 4th gear
16- 5th gear
21- reverse gear
HERE IT IS!
6- 1st gear
8- 1&2 synchro
12- 2nd gear
14- 3rd gear
16- 4th gear
19- 5th gear
AudiWorld Expert
<center><img src="http://pictureposter.audiworld.com/6607/5speed.jpg"></center><p>1- motor
2- clutch/flywheel
3- gearbox
4- gearbox input shaft
5- pinion gear & shaft
6- differential planet gears
A- ring gear
T- speed-o-meter pickup
Gears marked accordingly, I, II, III, IV, V, R.
2- clutch/flywheel
3- gearbox
A- ring gear
well similar...
actually i'm going to do my 2nd gear synchro, which is exactly the same as the first gear synchro!
That is, you'll want to replace item 8
Furtrader
SoCal Discussion
09-24-2005 12:29 PM
