94 CQ 12v Valley pan bolts loose, gasket looks good.
#11
Get a small diameter telescoping magnet from Lowes and run it down that hole and see what you come up with. It worked for me when I deopped a bolt straight down the spark plug hole. At least it has a chance of picking up that piece before you take apart the upper or lower oil pan.
*le sigh*
#12
Take a picture of the hole it fell into - I have a block sitting on my workbench with no oil pans on it. I should be able to tell you where it goes when I get home
#13
Top of the head, just below the cam. There are 4 of them total. Let me know if you need a wider view for perspective.
![](http://dagorlad.just-another.net/images/top_of_head_with_arrow.jpg)
#14
Took a leap of faith, drained the oil and pulled the bottom pan. Got it. Yay!
Next question: can I use black ATV to seal the pan back on? The seal is still there, but a tad pulled off.
Also, do the 95 oil check valves in the head work on the 94? Different construction but appear to be functionality equivalent.
#15
The anti-drain valves are dealer only. I replaced mine a few years back, did not notice any difference so chances are they were fine but I did it anyways since it was there. I bought a new valley pan as well just to start fresh.
You can buy them from genuinevwaudiparts for $36.89 each + 10 bucks shipping.
It is where I bought mine.
078103175D $59.50 $36.89<-------their price.
Any other dealer only item you need now is the time to buy it as their shipping stays flat until $100 then it gradually goes up by a few bucks.
#17
#18
#19
Gvap has great service and the only place to go for dealer items at wholesale pricing.
I saved a fortune so far vs my local dealer.
They also verify per your VIN any parts to make sure you get the correct item and if not they will notify you before going forward.
#20
Got it all running. Runs sooo much quieter and smoother now. Still seem to have a minor oil leak. Going to pull it into the garage this evening to take a look.
Thanks everyone for their help and suggestions.
laxman1100
08-13-2006 06:50 AM
UrSoccer_mobileĀ®
06-11-2003 08:12 PM
