95 90 Afc easiest way to remove upper oil pan
What's the easiest way to drop the sub frame or lower it to get at the rear bolts for the upper oil pan. I guess I need some in depth details.
Thanks Duane, MI
Thanks Duane, MI
You don't need to drop the subframe. Get the front wheels up on ramps and chock the rears. Use a jack with a strategically placed 2x4 (to disperse the weight) and lift the engine.
Ok the car is on ramps I have the oil pump removed with lower pan so undo all motor mounts? I need thorough details I guess. I need to pull the upper pan to check the crank bearing shells.
Randolph
12-22-2010 05:22 PM
vwp914
08-09-2007 09:29 AM
quattro90S6
06-27-2005 04:34 PM
