AC Upgrade?
Hello, I drive a 1988 Audi Quattro 80. It runs great however the Problem I have has to do with the AC system. The system needs to be recharged however my mechanic says that the gas is no longer being made much and is horrablly expensive. So, Is it possible/worth the effort to get an AC upgrade? What are your suggestions?
It's basically only a matter of evacuating the existing r12 from the system, getting two adapters for the high/low ports, and filling with the proper amount of 134 AND 134-specific oil. Your wrench should be able to do all of the above for under $100 (They sell the r134a recharge kits at Autozones for $30-$40 bucks; very inexpensive. Good luck.
Replacing a hose or two can be expensive, but it is better than running out of freon all the time. And better for the atmosphere.
Well, I know why I lost it... it is pretty much because when I was in the engine, I unscrewed the pipe leading out of the accumulator by accident =( otherwise, no leaks.
You may have to swap out the whole evaporator/heater core container, as one works with cables (3 dial) and the other works either with motors or vacuum controls (I don't know which). May be more trouble than it's worth...
Try a search?
Try a search?
When I got the heater fixed a while ago, the electronics got all messed up. Anyways, what would be the most compatiable year/model?
19885ktqcd in Wa. st
07-11-2003 07:20 AM
j14
02-27-2002 05:39 PM
